Members TinkerTailor Posted November 3, 2016 Members Report Posted November 3, 2016 (edited) 1 hour ago, Uwe said: A nice, thorough tutorial on that machine, with threading details and all. Uwe: Best part is at 6:45.....nsfw Pyrofx: in the picture above, you have your machine threaded through an extra guide right after the takeup spring. Watch the video at 10:20 or so, It should go straight to the take up lever through the single guide. This may be affecting the thread takeup which can effect knot formation. Also, quickly try flipping the bobbin over so it turns the other way. On some machines the thread comes off the bobbin easier in one direction or the other. If the machine tensions were setup with the bobbin turning one way and you flip it, it can change the bottom tension either lighter or heavier depending which way the bobbin was installed when the tension was set originally and stitch quality will suffer. Sometimes the solution in these cases is to back off the tension on both the bottom and top all the way and start again. Then use a sharpie to mark an arrow on the bed to remind you which way the bobbin needs to go in. Edited November 3, 2016 by TinkerTailor Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
Northmount Posted November 3, 2016 Report Posted November 3, 2016 Something strange! Usually top tension increases with a thicker thread if you haven't adjusted anything. Seems strange you have less top tension. Go back to 69 thread and make sure it still works, then try 90 on top with no adjustments to see what you need to change. Then go for 90 on the bottom. See what result each change produces. Tom Quote
Members pyrofx Posted November 3, 2016 Author Members Report Posted November 3, 2016 Going back to 69 everything is fine. That's why I'm stumped. The hippo vid I have watched 10 times. As for threading it is as the manual shows. I'll try reversing The bobbin. Something I noticed is that 4 layers and it sucks in. Cottons all is good. I'll try leather when I get back off the trip. The discs do release. I can see and feel it. Quote
