Members photoguy13 Posted December 14, 2016 Members Report Posted December 14, 2016 I am working with a new Techsew 2750 and was wondering if anyone could help me understand how I can eliminate any markings from the presser feet. I have adjusted/loosened the tension knob and still doesn't seem to eliminate the problem. Thanks Quote
Members rejerome Posted December 14, 2016 Members Report Posted December 14, 2016 I'm running a Cobra 4 and have that. I think it's fairly normal to have a least some tracks. I just remove those tracks with a glass slicker. Quote
Members photoguy13 Posted December 14, 2016 Author Members Report Posted December 14, 2016 Thanks so much Quote
Members Yetibelle Posted December 16, 2016 Members Report Posted December 16, 2016 You can always get a second (or third) set of feet and feed dogs and file\sand them down to a bare minimal or amount of grip. You really don't need all that much traction all the time. Quote One day I hope to learn how to sew..... Singer 111W155 - Singer 29-4 - Singer 78-1 - Singer 7-31 - Singer 109w100 - Singer 46W-SV-16 - Adler 20-19 - Cowboy CB-4500
Members Singermania Posted December 18, 2016 Members Report Posted December 18, 2016 Hi, I'm Steve Bonnett of Cowboy Leather Machines in Australia, I've been shouted down for this advice in the past but will risk the wrath once again. There are two ways to reduce the downwards foot pressure, the first is similar to new Cowboy machines that come with an extra lighter foot bar spring and the second is to take out the long foot bar coil spring and take off an end coil. Whilst this does effectively harshen the spring rate, it actually works as the spring was previously under compression even with the thumb screw at its top most point...... buy taking off a coil or two you can get the thumb screw started without compressing the spring. You don't need a lot of compression if you have a needle feed or compound feed machine. This does work, I have done it and advised it many times. Quote
Members Darren Brosowski Posted December 20, 2016 Members Report Posted December 20, 2016 On 18/12/2016 at 9:36 PM, Singermania said: Hi, I'm Steve Bonnett of Cowboy Leather Machines in Australia, I've been shouted down for this advice in the past but will risk the wrath once again. There are two ways to reduce the downwards foot pressure, the first is similar to new Cowboy machines that come with an extra lighter foot bar spring and the second is to take out the long foot bar coil spring and take off an end coil. Whilst this does effectively harshen the spring rate, it actually works as the spring was previously under compression even with the thumb screw at its top most point...... buy taking off a coil or two you can get the thumb screw started without compressing the spring. You don't need a lot of compression if you have a needle feed or compound feed machine. This does work, I have done it and advised it many times. What Steve said!!! Quote
