THANKS!  to everyone for there help. It's in the van, will unload today. It's definitely a 2 man job without removing the motor. We did bring it down upside down. I'm glad I took a turkey baster to remove the oil. NO sewing machines or human's were harmed in this move!
  • 11 months later...
I just moved one myself in my Venza. thanks to this post
I tilted, Drained, Funneled, Removed the head AND the motor (and light) and then it slid in on its back into the hatch.
From what I have seen and read when installing the motor should sliiiiide onto the bolts with some washers and nuts just there to hold it until you get the third one in and tighten it up.
Not in my case, there were some super rubber and metal bushings on there. I had to hold the motor up with 1 hand while I put a bolt through the hole and then a nut on the bottom.
Whew it's done! Its running but I do not believe it is oiling well.
thanks Sled
Edited by Sledzep01
Remember, Whether you think you can, or think you can't. You're Right!
Tell me and I forget. Show me and I remember. Involve me and I understand.
It is in the religion of ignorance that tyranny begins
