Members mixmkr Posted March 23, 2017 Members Report Posted March 23, 2017 So, of course I broke my needle bar thread guide on my JUKI LU562, trying to open it up a bit, as I was beginning to have problems feeding my 138 thread into it. The machine has been able to sew fine without it, albeit I'm taking it slower, as I have projects I MUST complete asap. Ordered and on the way. So...other than help guide the thread into the needle groove, (use a zip tie..ha!), am I missing an important function? Quote JUKI LU562, Singer 107 W1, Thompson PW201 mini walker, a couple of plastic fantastics for light duty "home stuff".... ya know...fixin' and altering clothes.....
Moderator Wizcrafts Posted March 24, 2017 Moderator Report Posted March 24, 2017 First, needlebar mounted thread guides position the top thread inside the rib along the side of the needle. In your case, it's the left side that has the rib. Second, by feeding the thread through this guide you keep it vertically aligned as it feeds down and through the eye of the needle. This reduces the amount of left deflection that tends to happen as you sew. The tighter the tensions, the greater the pull to the left as the needle goes in and out of the material. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members mixmkr Posted March 24, 2017 Author Members Report Posted March 24, 2017 thanks Wiz. Doing outside canvas work, I'm not seeing an appreciable drop in stitch quality and I understand the left pull you describe. I'm set at maximum stitch length...about 7-8mm, so I'm not getting all zig zaggy either. Quote JUKI LU562, Singer 107 W1, Thompson PW201 mini walker, a couple of plastic fantastics for light duty "home stuff".... ya know...fixin' and altering clothes.....
Members Constabulary Posted March 24, 2017 Members Report Posted March 24, 2017 Never liked this thread guide - I once replaced mine with a different type thread guide from a Singer 211 but I don t have the parts number - sorry. I think it was from a 211G model Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
