Members mojave Posted April 6, 2017 Members Report Posted April 6, 2017 Hi, All, How do you cut out patterns? Do you cut on the line, on the inside edge of the line, or on the outside edge of the line? The reason I'm asking, is because sometimes my pattern parts don't match up. Some were on this site I seen this discussed but can't find it again. It had something to do with the width of the pattern line. Thanks, Howard Quote
Members OLDNSLOW Posted April 6, 2017 Members Report Posted April 6, 2017 I try to cut right on the line so that once cut it will not show the ink on the leather, but as I get older and hands hurt more and become a little more unstable it doesn't always work out that way. If I do cut right on the line both pieces will line up. I am sure more of the well seasoned folks can provide better info so we can get some popcorn sit back and read the comments as they roll in. Quote
Jimmy McLaughlin Posted April 25, 2017 Report Posted April 25, 2017 I have the same problem. I watched a video on you tube. He was showing how to use a head knife. He traced his pattern and made it a point to mention how to cut it out. He said that he traces his out with a tracing awl and when he cuts it out he splits the line right down the middle. Makes sense, sounds easy enough, we all know about that LOL. I forgot what video it was, check out you tube. It showed him splitting the line down the middle, as always it looked very easy. He did mention look in front of the knife. I hope it helps you, I am still working on it. Jim Quote
bikermutt07 Posted April 25, 2017 Report Posted April 25, 2017 I have the same problem. I watched a video on you tube. He was showing how to use a head knife. He traced his pattern and made it a point to mention how to cut it out. He said that he traces his out with a tracing awl and when he cuts it out he splits the line right down the middle. Makes sense, sounds easy enough, we all know about that LOL. I forgot what video it was, check out you tube. It showed him splitting the line down the middle, as always it looked very easy. He did mention look in front of the knife. I hope it helps you, I am still working on it. Jim What little I have used my head knife, it's been spot on and a pleasure to cut with. Did I have to have it? Probably not. But I like it. You can sure zip around corners with it. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
