bikermutt07 Posted April 20, 2017 Report Posted April 20, 2017 I would like to see an aerostitch clone. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members JimTimber Posted April 20, 2017 Members Report Posted April 20, 2017 I've seen the Boss first hand and there's nothing about that machine that needs cast iron for the body as long as wear surfaces were sleeved/inserted with a more durable material. Did they cheap out back in the day? I can't comment on that. I've never looked closely at them. Quote
Members Singermania Posted April 20, 2017 Members Report Posted April 20, 2017 I've been collecting and repairing machines for many years and have had numerous Boss's thru the workshop, I find that the old cast iron Boss was quite good but all the same did require some mechanical ability above that normally required with other machines. The action of the machine contributes to its need for adjustment as being banged into end stops each stroke is hard on its settings. Its not so much a matter of bearings as was mentioned its something else. The newer machines despite what is said above have been problematical, it is rare to find owners that are happy with them, more often they are fed up and go and buy another machine of a different kind. For similar money you can get compound feed, reverse, motor and a longer cylinder. The recurring story I hear about the machines is that they get out of timing (somewhere), the owner sends them off for service, they come back and within a short time the fault is back again. I've had similar experiences with them here on my bench, I reset them, they work great, I then give them a final test the next day before sending them back and they seem to be off the boil again. It can be a very frustrating machine. When the issue is corrected then I'm guessing it will be a different story. Quote
Members Darren Brosowski Posted April 24, 2017 Members Report Posted April 24, 2017 The Cowboy Outlaw is cast iron and I have disagree that aluminium is suitable for the frame To keep the weight down the castings are relatively thin and when changing between cast iron and aluminium they did not thicken the casting to compensate for the difference in material properties. It only takes a tiny amount of flex in a sewing machine frame to cause problems. By basing the machine on a cast iron frame - as well as all the other modifications - the Outlaw will outperform the original Boss Quote
Members Singermania Posted April 24, 2017 Members Report Posted April 24, 2017 Yes Darren, Cowboy has poured heaps of money into the project, its not a complex machine so I'd be expecting a great result. Quote
Members Deryk Posted December 20, 2017 Members Report Posted December 20, 2017 Since this post is several months old I decided to email CowBoy to see if they have any idea when it will be coming out. Quote
Members Deryk Posted December 20, 2017 Members Report Posted December 20, 2017 very surprised, got an email back from Ryan Neele the US guy Hello:Yes, the Outlaw will be a much improved version of the Boss.It will have a longer arm, all cast iron construction, and will have a bigger hook and bobbin.The machines should be here around the first week of March.It should be a much better machine than other hand crank versions on the market.Ryan Quote
Members Singermania Posted December 20, 2017 Members Report Posted December 20, 2017 In Australia we at Cowboy Leather Machines market two hand crank models, we have the CB2500HC and the CB3200HC at $1350 and $2600 respectively. The former a basic drop feed machine ie driven by feed dog and the latter a compound feed machine. We are keen to get our hands on the Outlaw as it will take our handcrank range to 3. And of course a completely different style to the sewing machine based machines above. The price in Australia should fit mid way between our two existing machines. Below is the CB2500HC Quote
Members Deryk Posted December 20, 2017 Members Report Posted December 20, 2017 Very sharp looking! Why aren't they being marketed in the US? Quote
Members Singermania Posted December 20, 2017 Members Report Posted December 20, 2017 Hi Deryk, don't know mate, its not rocket science we just drill and tap the handwheel and put an engineers steel handle on. Its takes off the cost of the table, speed reducer and motor, however we still include all the feet, plates and roller guides. People here like them cos they are a lot cheaper but also they can toss into the truck and take to shows and so on the spot repairs for income. If you have a word with Ryan Neel or one of his dealers they'll probably make one. Quote
