Members arz Posted June 19, 2017 Author Members Report Posted June 19, 2017 @Trox Thanks! I would like to buy the Italian one. I am now waiting to here back from the dealer if they can change it to 220V for me (this one is currently setup for 380V). -Adam Quote Machines in use: Ellegi (Atom GL12 ) skiving machine, Durkopp Adler 69-373 sewing machine Atelier Zander: Website Instagram
Members arz Posted June 20, 2017 Author Members Report Posted June 20, 2017 The dealer said they cannot change the motors to 220V. I would have to replace the motors etc. I'm not sure how involved that would be. We are busy enough at the moment so that option does not appeal to me. He is looking for another machine for us. I can wait so that's fine with me Quote Machines in use: Ellegi (Atom GL12 ) skiving machine, Durkopp Adler 69-373 sewing machine Atelier Zander: Website Instagram
RockyAussie Posted June 20, 2017 Report Posted June 20, 2017 Must be a different set up to mine as it only runs a single 3/4 hp motor to run everything off belts and pulleys etc. Feed wheel is controlled by a clutch which as you can see in my video gives pretty good control. I just took a couple of pics below of my machine that could help.. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members arz Posted June 20, 2017 Author Members Report Posted June 20, 2017 @RockyAussie Thanks! This one has two motors: One on the right that has one belt that controls the knife/clutch (inside the machine is a typical clutch setup with a belt that goes to the feed clutch). The second motor is on the left cabinet that powers the vacuum. Quote Machines in use: Ellegi (Atom GL12 ) skiving machine, Durkopp Adler 69-373 sewing machine Atelier Zander: Website Instagram
Trox Posted June 20, 2017 Report Posted June 20, 2017 Mine has three motors, one 380V for the knife that runs on full speed. One for the suction device, also 380 V on full speed. And a little 12v DC motor inside the head for the feed wheel. I do not have three phase (380V) in my workshop, so I just connected a frequency controller. It's plugged in my 220V single Ph outlet and four leads goes from it to the 380V inlet on the machine. The controller converts single 220v in to three phase 380V. And the hertz controller on it gives the full 50 hertz all the time, motors run at full speed as they must on this set up. That's how easy it is to do this, ask Gigi for help. By the way all AC motors are initially a three phase motor. Tor Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Members arz Posted June 20, 2017 Author Members Report Posted June 20, 2017 16 minutes ago, Trox said: Mine has three motors, one 380V for the knife that runs on full speed. One for the suction device, also 380 V on full speed. And a little 12v DC motor inside the head for the feed wheel. I do not have three phase (380V) in my workshop, so I just connected a frequency controller. It's plugged in my 220V single Ph outlet and four leads goes from it to the 380V inlet on the machine. The controller converts single 220v in to three phase 380V. And the hertz controller on it gives the full 50 hertz all the time, motors run at full speed as they must on this set up. That's how easy it is to do this, ask Gigi for help. By the way all AC motors are initially a three phase motor. Tor Hmm...sounds easy enough. How much does a frequency controller cost? This machine is just like yours but does not have a servo for the feed. Quote Machines in use: Ellegi (Atom GL12 ) skiving machine, Durkopp Adler 69-373 sewing machine Atelier Zander: Website Instagram
Trox Posted June 20, 2017 Report Posted June 20, 2017 Depended of how much amp and watt the motor is on, you got to buy a little bit over size. You can get them used on Ebay. I would guess it's possible to get one new (the right size) for the machine between 50 to 70 USD. However, it's easy to rewire a three Ph AC motor to single too. All you need a capacitor to mirror one of the Phases, See pic. The bigger the capacitor is, the less torque you loose. Because, the AC motor is always stronger when it runs on three ph, than on single. Here I've have used two big capacitors instead of one. But they are connected the same way as with one. It's an 1 KW AC motor for a air compressor. The frequency controller is the best option when you need the possibility to adjust the speed of the motor. I used them on everything from sewing machine clutch motors to the skiving unit. I always have some laying around. Gigi uses one on their skiving machine too. I always use the easiest method when I need to connect a three Ph motor to a single Ph net. On the skiving unit I would have to rewire two motors with capasitors. Therfore I just plugged it in to a frequency controller, much easier. You also have to connect a little switch, for the startup of the machine. I only used a little lamp switch ( I used a foot button lamp switch with two wires/poles). Of course you have to read the Pdf instructions/manual for the controller. The Watt and amp rating on the motor desides how big it has to be. This is one on 0,75 KW. The single current from wall outlet comes in on the top, the white cable goes to the start switch (lamp switch). And the four other goes to the motor conections(or machine input box). To connect the four (output) wires for the motor: Earth on earth of course, then you just going to try with the three others. There are three contacts on the motor where they should be conected. If it doesn't start, change them around and if it starts and goes the wrong direction; change them around again until it starts and goes the right direction. There is no other way to connect these, try and fail (it's not dangerous). With this type of controller you can control every parameter on a AC motor if needed, like tourque, speed, startup time/stoping time you name it. But in this case you do not have to do anything else than set the hertz to full (full speed) This is easy to do if you know the principals, if not get some help from an electrician. Tor Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Trox Posted June 20, 2017 Report Posted June 20, 2017 Before I can recommend you using one of these methods I got to see the setup, motors and the connection box on the actual machine. If there are two three Ph motors on it, one clutch motor and a regular AC motor (one speed). Then both these methods will work fine. But if one of the motors are a DC servo motor or the machine has an electronic inbuilt speed control, then it's a difficult task. It still might be possible, but a much more difficult project. Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Members arz Posted June 20, 2017 Author Members Report Posted June 20, 2017 @Trox Thanks for the detailed info! This is a basic machine, no servo or electronic control. Atom in the UK sent me the manual so I have the electrical schematics. To be honest it may be able rewire it for 220V (it maybe 220/380V). I should have looked closer at the motors when I saw the machine. I think the dealer just doesn't want to deal with it. I have done a fair amount of electrical work in the past. Looks like the controller would be easy to do. Could I just take the existing power cable and wire it into the controller (instead of wiring it directly into each motor)? Thanks! -Adam Quote Machines in use: Ellegi (Atom GL12 ) skiving machine, Durkopp Adler 69-373 sewing machine Atelier Zander: Website Instagram
Trox Posted June 21, 2017 Report Posted June 21, 2017 22 hours ago, arz said: @Trox Thanks for the detailed info! This is a basic machine, no servo or electronic control. Atom in the UK sent me the manual so I have the electrical schematics. To be honest it may be able rewire it for 220V (it maybe 220/380V). I should have looked closer at the motors when I saw the machine. I think the dealer just doesn't want to deal with it. I have done a fair amount of electrical work in the past. Looks like the controller would be easy to do. Could I just take the existing power cable and wire it into the controller (instead of wiring it directly into each motor)? Thanks! -Adam Of course, that is what you do. Just for illustration I wrote it like that. I've been using these controller for many years and not had any problem with them. Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
