Members oldtimer Posted April 20, 2017 Members Report Posted April 20, 2017 A couple of years ago I found an article on the web how to refurbish a 29 K machine, to repair a worn part that determines the stitch lenght I can´t find the article again . Anyone ? / OldTimer Quote
Members Yetibelle Posted April 20, 2017 Members Report Posted April 20, 2017 There are a few 29k restoration links out there. http://northants-restoration.blogspot.com/ This one is a word doc, with pictures not sure if the link will work in here? https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=14&cad=rja&uact=8&ved=0ahUKEwiq2MSlubPTAhVKPiYKHUuJDMIQFghoMA0&url=http%3A%2F%2Fneedlebar.org%2Fmain%2Frestoration%2FSinger29K13.doc&usg=AFQjCNEA0DvpI_cgnioBfZRNQbNTqgeKbQ Quote
Members shoepatcher Posted April 20, 2017 Members Report Posted April 20, 2017 It has to do with restoring the "figure 8" on the end of the bell crank. The lobes wear down on each side and that causes the stitch length to shorten. If someone is a competent welder, the lobes can be welded up with a Tig or Mig Welder and reground with a Dremel and you are almost good as new. I have 30 plus bell cranks from Adler and Singers that have to be welded and reground on the lobes. That is a project for when I retire. That is normally the only thing to go wrong with a used bell crank. glenn Quote
Members Yetibelle Posted April 20, 2017 Members Report Posted April 20, 2017 1 minute ago, shoepatcher said: It has to do with restoring the "figure 8" on the end of the bell crank. The lobes wear down on each side and that causes the stitch length to shorten. If someone is a competent welder, the lobes can be welded up with a Tig or Mig Welder and reground with a Dremel and you are almost good as new. I have 30 plus bell cranks from Adler and Singers that have to be welded and reground on the lobes. That is a project for when I retire. That is normally the only thing to go wrong with a used bell crank. glenn You don't happen to have a few pictures of the worn parts and what the new/restored parts are suppose to look like? Quote
Members oldtimer Posted April 20, 2017 Author Members Report Posted April 20, 2017 22 minutes ago, shoepatcher said: It has to do with restoring the "figure 8" on the end of the bell crank. The lobes wear down on each side and that causes the stitch length to shorten. If someone is a competent welder, the lobes can be welded up with a Tig or Mig Welder and reground with a Dremel and you are almost good as new. I have 30 plus bell cranks from Adler and Singers that have to be welded and reground on the lobes. That is a project for when I retire. That is normally the only thing to go wrong with a used bell crank. glenn Do you have a pic of the part named bell crank? Quote
Members Yetibelle Posted April 20, 2017 Members Report Posted April 20, 2017 here is that Singer 29k part chart. Very handy. Quote
Members Constabulary Posted April 20, 2017 Members Report Posted April 20, 2017 I once restored a 29K1 so this thread may be useful for you: Quote
