What HP consew motor  should I replace the old clutch motor with?  The motor in it now is Industrial Clutch Motor, 1/3 HP, volts 115, amps 40, rpm 1725, model 131L.
And do you have suggestions as to where to buy the motor.
If you're in the US the simplest solution would be to contact one of the advertisers on here. A 3/4 hp (550W) would be more than adequate. It doesn't have to be a Consew motor, most any brand servo would work.
