Members beltbuckles Posted June 2, 2017 Author Members Report Posted June 2, 2017 (edited) On 5/14/2017 at 5:40 AM, Uwe said: The Pfaff 138 gets my vote. There's a detailed topic on that machine: On 5/14/2017 at 5:58 AM, alexitbe said: I have a pfaff 138-6 and it is a Tailor's sewing machine. It should come with lots of feet. I have been looking for a wheel presser foot for light weight leather, but there, I have had no luck. I like the pfaff 138. There are 3 needle positions and max zig-zag width is about 5 mm and max stitch length is about the same... Will that suit what you want to do? Cheers Alex On 5/14/2017 at 6:23 AM, Constabulary said: I´d take the 138 too. I once owned one - very smooth running machine when properly set up (as most other sewing machines too). It is more or less the forerunner of the 438. I´m not sure if it has a build it oil pup or if it is wick oiled (from a reservoir) most built in oil pumps work at high sewing speed only. Also the 438 has a timing belt which sooner or later needs to be replaced (maybe tomorrow - maybe in 5 years) and replacing these belts often is a pain ITA or cost some good money. The 138 has a drive shaft instead (is it called drive shaft?) which needs no replacement. The only known problem of the 138 is probably that the zigzag adjuster could be gummed but thats something you can solve with heat and oil w/o bigger problem. When your zig zag adjuster is not gummed - even better. The 138 is well documented as well you find everything from manual to parts list and service instructions online. Though I have not checked for the 438. However - If I had to choose I´d take the 138. On 5/14/2017 at 6:40 AM, mikesc said: Another vote for the Pfaff 138-6..very solid machine. I actually have ( amongst others ) a Singer 20U ( wanted it for the freehand embroidery potential due it's variable zig-zag ability ) and the larger zig zag ( 8 to 9mm bight )..now looking for a triple step zig-zag ( hoping to find a Bernina 217..rare now ) to supplement it. sooo............i got a few of them... "bulk deal" and i did get the 138 (along with a 335 and 2 adler 69's... some parts are missing so now i am hunting them down.. the machine seems to be okay.. i am now ordering a foot and a needle set for the machine (138) if it runs smooth, (or when i guess i should say), ill get a table and motor for it.. THANKYOU for your advice and kindness.. really quick, .. as far as needles go.. what size would be good to start with ? and are parts interchange able with other brand machines (singer, ...ect..) Edited June 2, 2017 by beltbuckles Quote
Members Constabulary Posted June 2, 2017 Members Report Posted June 2, 2017 (edited) Sounds like a good deal. The 138 I´d start with a size 100 / 120 (metric) needle and the other with size 120 /140 needle (metric). Singer parts will most likely not fit - maybe a few screws or springs but within a brand some parts are interchangeable since f.i. the 69 is using a lot of parts of the 67 /167 and the 335 parts of the 145 / 545 and so forth... BTW - the 138 has gearboxes (usually 3 - 2 on connection shaft and 1 for hook driving) I´d clean them and fill with new grease Edited June 2, 2017 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
