Kohlrausch Posted July 10, 2017 Report Posted July 10, 2017 On 8.7.2017 at 9:30 PM, Chayse said: The title says it all and I couldn't resist! Overall it is in good cosmetic condition and seems to have been looked after properly. It is worn, like so many these days, only gets 8 SPI.. Hi, 7 spi are factory standard. Greets Ralf C. Quote
Members Constabulary Posted July 10, 2017 Members Report Posted July 10, 2017 (edited) 2 hours ago, Kohlrausch said: Hi, 7 spi are factory standard. Greets Ralf C. Thats mentioned in a 29K71 - 73 manual but I think it is a misprint. My 29K71 right now has 4.5mm - 4.6mm - thats approx 5.5 SPI. So 7 SPI in the manual can´t be right. Edited July 10, 2017 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Moderator Wizcrafts Posted July 10, 2017 Moderator Report Posted July 10, 2017 On 7/8/2017 at 10:22 PM, Chayse said: I have absolutely no idea what the large awl type tool is in the top left...is sharp tho! I think some of the fun is finding what, if any, hidden treasures might be stowed away in the drawer! I replaced the feed motion crank in my 29k71 two years ago and after filing the new "puck" for the best fit in the ring, it consistently gives me 5 spi Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Chayse Posted July 11, 2017 Author Members Report Posted July 11, 2017 Thanks for everyone's input thus far as I still have to find the time to disassemble the machine and give it a good clean and inspection. I think it is then that I will have a better understanding of the next steps to take. I am still a novice, so the actual stitch length doesn't bother me as much and I am sure it will all come together on different projects and finding the stitch length that is aesthetically pleasing to fit the project at hand....all in due time I guess! Quote
Members Chayse Posted July 11, 2017 Author Members Report Posted July 11, 2017 3 hours ago, Wizcrafts said: I replaced the feed motion crank in my 29k71 two years ago and after filing the new "puck" for the best fit in the ring, it consistently gives me 5 spi @Wizcrafts...are you referring to Part #82149...Feed Motion Cam Wheel? By your description of the slight modification, I think I have the right part narrowed down. But through reading of your various threads pertaining to the 29K's, particularly the later models, I know it can be a number of things...will take it slow and see how it goes. I know for sure that I have a bit more than a 1/16th movement at the bell crank lever..at least it gives me a place to start. Thanks for your insight! Quote
