Members Toryc99 Posted August 4, 2017 Members Report Posted August 4, 2017 Hi, I need a really heavy industrial adhesive that is still sewable..any recommendations? Thanks! Quote
Members YinTx Posted August 4, 2017 Members Report Posted August 4, 2017 Depends... what are you using it on? YinTx Quote
Members Sonydaze Posted August 4, 2017 Members Report Posted August 4, 2017 Welcome to the forum, it can be a great source of both information and inspiration. Giving more information of what you are sticking together and adding where you are located to your profile helps folks to give you better answers. In Western Canada, I like Duropro Contact Cement. It has a good working time, sticks well and sews okay. Make sure it is well cured before sewing. Quote
Members cowboycolonel Posted August 4, 2017 Members Report Posted August 4, 2017 I use Barge's or Master's. Master's is more readily available, but you can get Barge's in small quantities at some hardware stores. The small quantities which are available without HAZMAT considerations (California) make Barge's cost prohibitive for large projects like saddles. With both products I have had very good success with tight and lasting bonds. Quote
