Members rodneywt1180b Posted November 21, 2017 Members Report Posted November 21, 2017 I'm looking at buying a stitching chisel. Most likely I'll buy either a 2 or a 3 prong one. I will most likely be using 0.6 and 0.8 mm tiger thread for my thread. I'm mostly going to be covering cane handles and making wrist straps for them. What size(s) stitching chisel would be best? Also, which cheaper brands would you recommend? I am on a budget and don't want to spend a lot. Thanks, Rodney Quote
Members rodneywt1180b Posted November 21, 2017 Author Members Report Posted November 21, 2017 I think I may have answered my own question. Springfield Leather has some diamond point chisels that should work. http://springfieldleather.com/Chisel-Diamond-4prong Quote
Members zuludog Posted November 22, 2017 Members Report Posted November 22, 2017 That chisel looks good value, but I think there could be a problem or misunderstanding You can sew leather with thread, and the chisel needs to have prongs that have a diamond shaped cross section, and set at an angle to the body of the chisel You can also sew leather with thin strips of leather, called lacing or thonging. The chisels for this have prongs with a flat section, like very small rectangles, and are set flat in line with the body of the chisel I can't quite tell from the picture, but it looks to me that this is a lacing chisel, which is not what you want. I think the word 'diamond' in the description just refers to the tips, which is confusing. Check with the supplier before you buy. Just tell them what you want to do, and they should advise you accordingly. I'd say prongs with 3 mm spacing Whatever chisel you get, it can be improved by polishing the prongs, especially the cheaper makes. Make a small file or buffing board by gluing some 500 or 600 grit wet & dry paper to a sliver of wood like a lollipop stick. And lubricate the prongs on a lump of beeswax as you use it In the short term you can hit the chisel with a steel hammer, which you may already have, but eventually this will damage the end of the chisel. You should use a soft hammer, like plastic or hide. Don't get a cheap rubber mallet, they will bounce and be difficult to control. Don't hammer on your cutting mat. I use a plastic kitchen chopping board about 12 mm thick Don't be tempted to wiggle the chisel around as you remove it, as this will distort the leather and possibly bend the prongs. Use a small length of wood to hold the leather down and go for a straight pull; the polishing & wax will help Depending on the thickness of your leather you might find that the prongs do not make perfect holes, in which case you will need to do some extra work with an awl, but cross that bridge when you come to it. I was going to reply anyway, as I don't think you can get 3 - prong chisels, you'll have to get 2 or 4 If you are going to make wrist straps they will be more comfortable if you bevel and polish the edges. Search YouTube and this forum for advice on that Quote
Members DJole Posted November 22, 2017 Members Report Posted November 22, 2017 24 minutes ago, zuludog said: I was going to reply anyway, as I don't think you can get 3 - prong chisels, you'll have to get 2 or 4 Very good tips up there, Zuludog. I just wanted to add that it is possible to get 3 prong chisels. My Leathercraft.JP set (http://goodsjapan.com/pricking-irons--stitch-punches-30-c.asp) in 3 mm pitch contains a 3 prong chisel (among others). Quote \D. Jole \ --> <http://djole.altervista.org/djole/Publications/Leather/Lindex.htm>
Members zuludog Posted November 22, 2017 Members Report Posted November 22, 2017 (edited) I've just re - read my post This part should be obvious, but lets clear up any possible misunderstanding When I wrote about lubricating the prongs with beeswax I meant, of course, as you knock the chisel through the leather, and not when you polish them with abrasive paper Use the buffing board dry or with water I've just searched YouTube for 'leather covered walking stick'. there are 3 or 4 videos that look relevant, but I haven't watched any of them Edited November 22, 2017 by zuludog Quote
Members rodneywt1180b Posted November 22, 2017 Author Members Report Posted November 22, 2017 I've noticed that Springfield uses the terms stitching and lacing somewhat interchangeably. I was hoping that one was actually for stitching. Thanks guys, the GoodsJapan prices seem reasonable and the tools look good. . I know with tools you tend to get what you pay for but my budget is limited. The GoodsJapan ones are within my spending range. I do have polishing equipment. Polishing the prongs, at least on the outer faces, won't be a big deal. I'll be using mostly a baseball stitch or possibly an X stitch on the wraps. I'm using a saddle stitch on the wrist straps. I'll most likely get the 3x5mm chisel to start. That should be a good compromise for my purposes. My first leather wrap was pretty crude. The only thing saving it is the rustic nature of the stick its on. I'm working on a cane right now that will be much more demanding. Straight lines and smooth curves are a must for it to look right. A decent stitching chisel will help. I'll post the new one when it's done. It's probably a couple weeks out from being finished. I'll take a look for the you tube videos. I'm curious about what they're doing. Thanks, Rodney Quote
Members rodneywt1180b Posted November 24, 2017 Author Members Report Posted November 24, 2017 I just ordered my stitching chisel from GoodsJapan. I'm getting the Seiwa 3x5 mm one. It works out to 5 stitches per inch which should work out well for the baseball and x stitches on my wraps. It should be here in a couple weeks, sooner if I'm lucky. Thanks for your advice guys. Rodney Quote
Members DJole Posted November 24, 2017 Members Report Posted November 24, 2017 On 11/22/2017 at 0:40 AM, rodneywt1180b said: I've noticed that Springfield uses the terms stitching and lacing somewhat interchangeably. I was hoping that one was actually for stitching. Thanks guys, the GoodsJapan prices seem reasonable and the tools look good. . I know with tools you tend to get what you pay for but my budget is limited. The GoodsJapan ones are within my spending range. I do have polishing equipment. Polishing the prongs, at least on the outer faces, won't be a big deal. I'll be using mostly a baseball stitch or possibly an X stitch on the wraps. I'm using a saddle stitch on the wrist straps. I'll most likely get the 3x5mm chisel to start. That should be a good compromise for my purposes. My first leather wrap was pretty crude. The only thing saving it is the rustic nature of the stick its on. I'm working on a cane right now that will be much more demanding. Straight lines and smooth curves are a must for it to look right. A decent stitching chisel will help. I'll post the new one when it's done. It's probably a couple weeks out from being finished. I'll take a look for the you tube videos. I'm curious about what they're doing. I wonder if these angled chisels will do what you want them to. They lay stitches out in the traditional slanted stitch for two pieces of leather on top of each other. Does the baseball or exterior X stitch, which are basically edge to edge, work okay with those slanted stitch holes, or will it look strange? Quote \D. Jole \ --> <http://djole.altervista.org/djole/Publications/Leather/Lindex.htm>
Members rodneywt1180b Posted November 24, 2017 Author Members Report Posted November 24, 2017 I'm thinking it will be fine. Maybe not perfect but ok. I also use a saddle stitch in my wrist straps and it will be great for that. At least they'll be in a straight line. Rodney Quote
Members DJole Posted November 25, 2017 Members Report Posted November 25, 2017 3 hours ago, rodneywt1180b said: I'm thinking it will be fine. Maybe not perfect but ok. I also use a saddle stitch in my wrist straps and it will be great for that. At least they'll be in a straight line. Yes, they'll be beautiful for the wrist straps. My stitching chisels were a lovely Christmas gift. Quote \D. Jole \ --> <http://djole.altervista.org/djole/Publications/Leather/Lindex.htm>
