Craftt
Cobra 26 bobbin help
Hi all I just purchased a cobra 26 and probably caused the problem myself but don't know what I did so I don't know how to fix it. I am getting loops on the bottom side of leather when I use reverse. Any help will be appreciated. Also is there a (factory set) on tension to begin with (like tighten all the way and back off one or two times) for both the primary and the bobbin?
Looping underneath is almost one of 2-things,either miss-threaded needle thread or upper tension too loose. Try tightening your upper tension 1/2 a turn @ a time until it clears up.
Thank you I'll try tomorrow
That did it thaks
