Members motocouture Posted January 20, 2018 Members Report Posted January 20, 2018 So, staring a prototype for a small clutch (eventually going to do in croc). Pic below shows outer and lining. I’ve glued the lining completely to the two side gussets, but I’m curious if the lining gets fully glued to the main body, or just close to the edges where it’ll be stitched? Also, how do you account for the turn when the main body is folded; do you simply make the lining shorter than the outer, if you’re not completely gluing the two together? Thanks! Quote
Members JMcC Posted January 20, 2018 Members Report Posted January 20, 2018 Hi Moto, Not sure if it's the correct method or not but I have made a couple of purses for my daughter and I have completely glued the lining to the inside. Seemed to work out fine for me. James Quote
Members motocouture Posted January 20, 2018 Author Members Report Posted January 20, 2018 3 minutes ago, JMcC said: Hi Moto, Not sure if it's the correct method or not but I have made a couple of purses for my daughter and I have completely glued the lining to the inside. Seemed to work out fine for me. James Hi James, thanks, good to know! Quote
Members JMcC Posted January 20, 2018 Members Report Posted January 20, 2018 Just now, motocouture said: Hi James, thanks, good to know! You're welcome and let us know how it turns out with the croc leather. Bet it will be nice! Quote
Members thefanninator Posted January 20, 2018 Members Report Posted January 20, 2018 I've done a similar clutch and I fully glued the lining. With some other types of bags the lining can be glued to just the edges. Quote
Members motocouture Posted January 20, 2018 Author Members Report Posted January 20, 2018 4 hours ago, thefanninator said: I've done a similar clutch and I fully glued the lining. With some other types of bags the lining can be glued to just the edges. Thanks! I think that’s the path I’ll head down 4 hours ago, JMcC said: You're welcome and let us know how it turns out with the croc leather. Bet it will be nice! Shall do! Quote
