Members Dunluce Posted January 31, 2018 Members Report Posted January 31, 2018 4 hours ago, jonasbo said: This is one way to do it: andersenleather.blogspot.com/2015/10/burnish.html The trick is to burnish the very edge of the edge before dyeing the edge. I also use a felt marker. A wool dauber should only be used if the edge is the same color as the leather. When you mentioned this I remembered that is where I saw the molotow markers being used http://andersenleather.blogspot.co.uk/2015/10/burnish.html i believe he also uses larger ones elsewhere for dying larger areas of leather. He does some quality work. Quote
