So without a bunch of confusing explanations I have drawn up a diagram to illustrate my question.
This case will open to a flat container.
The buckle I am using is a rectangle with sliding center.
Which should be the billet and which should be the buckle in this scenario?
I would keep the buckle on the bottom or underside piece, but it's really a matter of personal choice.  with the buckle on the top flap your strap will be fastening from bottom to top, but if it's not something that will be carried around like a satchel i wouldn't see an issue either way.
