Members Kryptonite Posted March 15, 2018 Members Report Posted March 15, 2018 (edited) Hi Guys, After having fun with my Singer 111W155 Rehab a few months ago.... I thought I would try it again. I purchased a Pfaff 545 H3 with motor/table for $100 because it would not sew. I figured it looked pretty good and chances are it could be fixed. It had at least 2 issues. The Safety Clutch had popped, which I reset. Second was the 2 pressers feet where not moving right. The Inside sort of looked ok. The outside foot was not moving at all, and its lowest position was 1/4" or so above the needle plate. I found the 2 screws that hold the presser bar in position and lowered the outside foot to touch the needle plate. After playing with the adjustment screws, as noted in picture below, for 2 hours trying many combinations I still could not get the outside foot moving at all. Could a Pfaff expert suggest a solution? Thanks, Will in Central Florida Edited March 15, 2018 by Kryptonite Quote
Members Kryptonite Posted March 15, 2018 Author Members Report Posted March 15, 2018 Got it :-) Presser Vid... Quote
Members Kryptonite Posted March 15, 2018 Author Members Report Posted March 15, 2018 (edited) Ok I think I figured this out maybe. I have 2 pressor tension leaf springs running along the top of the machine. If I remove one spring the outside foot seems to be walking. So if that is the fix... why does the parts manual show 2 springs (661 - 662)? Maybe something pertaining to the knee lift operation? My machine head is not mounted in the table right now. Cheers, Will from central Floida Edited March 15, 2018 by Kryptonite Quote
Members Haderimouve Posted March 15, 2018 Members Report Posted March 15, 2018 (edited) Hi Kryptonite, Sorry not to be helpful ... I also have a 545 with EXACTLY the same problem ! Hope that some guys will be able to give some help ! Edited March 15, 2018 by Haderimouve Quote
Uwe Posted March 15, 2018 Report Posted March 15, 2018 Your feet don't walk because the front foot doesn't really make contact with and press against the feed dog - it simply goes in circles above the feed dog. The rear foot can only lift up if the front foot can press against something (feed dog or material.) If you put some 1/4" thick material under the feet, they will probably walk right now because the front foot can press against the material. As to why your front foot doesn't touch the feed dog, I can't tell from the information you provided. Quote
Uwe Posted March 16, 2018 Report Posted March 16, 2018 Here's how my Pfaff 545 is adjusted to get proper walking foot movement: Quote
Members Haderimouve Posted March 16, 2018 Members Report Posted March 16, 2018 Hi Kryptonite, hi Uwe, Pfaff mechanic best Guru ! Finally, I was so in hurry to test your adjustments that I went quickly home to "play" with the screwdriver ! First I tried to change the "Factory" eccentric setting : I unscrewed the two bolts and tried to move the axle with the rod : Impossible to move it !!! Maybe with the help of heat ... (The machine is more than 40 years old, everything is very tight on it !), I just gained to loose one bolt in the foundry and spent about half an hour to recover it ! But comparing your machine's setting in the video with my machine's actual setting, I realized that this eccentric on my machine was about to be rightly settled. Then, I had a look to Kryptonite post and read your reply : I tried to settle again according your advices (Compensating the presser foot with 6-7 mm material) and ... Magic ! Now it works superbly!!!! Thank you very much for your help ... This machine was in a Spanish mechanic shop and the specialist told me that the machine was too old, suffered too much, that the repair was impossible : I was so sad and deseperate because I love this old Pfaff machines ; So many 545 that have really worse state of preservation than mine are working fantastic, smoothly ; I didn't believe the mechanic that told me that the machine was out of order and I was right ! Please Uwe, continue to edit more such videos : With your experience and official technical informations of settings, we are all able to fix our old sewing machines. If you plan to visit Spain, I would love to invite you for lunch or dinner here in Madrid ! Thanks a lot, Haderimouve. Quote
Members Kryptonite Posted March 17, 2018 Author Members Report Posted March 17, 2018 Uwe you were absolutely right. There was not enough pressure on the front foot to enable the outside foot to lift. Thank you so much for the video. I followed the steps you outlined and now my dancing like they just left the factory. I looked at the hook timing and the hook is just missing the needle in the middle of the scarf... I think I'm in business. I am hoping to run some thread through the machine this weekend to see if it sews. Thank you again for taking the time to share your knowledge. You help make this Forum great! And I'm sure many people will benefit from the video as there is not much information about the Pfaff 545 foot timing. Cheers, Will in Central Florida Quote
Members imawalkingfoot Posted November 29, 2020 Members Report Posted November 29, 2020 On 3/15/2018 at 5:36 PM, Uwe said: Here's how my Pfaff 545 is adjusted to get proper walking foot movement: Hi uwe, Follow the steps on the video but now I have another problem on my pfaff 335 Soon as I start using the machine, the front feet is pushing more pressure onto the needle plate and i can see the needle plate bend down a little bit? Have you encounter this before? If you have, what is the solution? Thank You Quote
