Thank you all for your suggestions. I am getting a little better with each practice and feeling a little more encouraged. I am about to be thrown in the fire on it though. Have a guy that wants me to make him a knife sheath with basketweave. Lord help me.
I will throw my hat in with some of the others and suggest a heavier tool. Of course you want to grip the stamp tightly and work on a surface that doesnt bounce but I find with a light hammer you have to strike it a few times or the hammer itself bounces. My maul is a touch under 2lbs but I have worked quite well with the 1lb garland. Once you set your stamp in place .... give it a WHACK! Being tentative about it I find is the worst culprit to shifting stamps and ghosts.
Something else that you may want to try which was suggested to me by someone here on the forums...get some of that elastic bandage wrap like they use in a doctor's office to wrap you after they stick you with a needle. Get it in a 1 inch width and use it to wrap your tool handle to make the stem of the tool fatter and easier to grip. It is also less tiring on the fingers. I am here to tell you that it works great for me. You can find that elastic wrap at any pharmacy chain store. Good luck :)
Just now seeing this reply. Believe it or not, that is how I just stamped my new project. I held the stamp somewhat firmly and whacked the stamp with commitment. I also held the stamp down low so my fingers were resting on the stamp portion itself. Seemed to help my problem some. Thank you so much for your input!
I think you are referring to Vet Wrap and I actually thought about using that, but wasn't sure how well it would work. Now I am going to give it a try and see how I like it. Thank you!
