Members Aven Posted April 22, 2018 Members Report Posted April 22, 2018 I have a 29K70 in relatively decent condition. After playing with it for a while I got to wondering would it be possible/would it worth moving the hand wheel from the side to the front of the machine? Quote
Moderator Wizcrafts Posted April 22, 2018 Moderator Report Posted April 22, 2018 On 4/22/2018 at 3:15 PM, Aven said: I have a 29K70 in relatively decent condition. After playing with it for a while I got to wondering would it be possible/would it worth moving the hand wheel from the side to the front of the machine? Expand You can do that if the required pinion gear is mounted inside the head, by the opening for the wheel, and a shaft comes out of a housing. Otherwise the cost of the parts may be as much as you paid for the machine itself. The entire top shaft would have to come out to install the gear for the side wheel drive. Further, you may have some interference from the wheel with certain work you are sewing. It sticks out well into the arm area. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Aven Posted April 22, 2018 Author Members Report Posted April 22, 2018 Thanks Wiz. Sounds like it would be an upgrade that I really don't need. Quote
Members Trevor Baret Posted April 23, 2018 Members Report Posted April 23, 2018 I have two 29K machines, and have had others. So far, all I have seen already have the shaft for both end and front positioning of the hand wheel. I have tried moving the wheel on one of the machines - for the sake of interest... No problem - I just took it off the end and put it on the front. I chose to keep it on the end, as this was more convenient for me and made it easy to transfer from treaddle use to hand cranking simply by positioning the belt. Quote "Just love preserving that old black cast iron" Our Current Industrial Singer Machines - 103K; 31M32; 31K48; 31K47; 132K6; 307G2; 17-8; 45K25; 29K58; and more coming... Our Domestic Singer machines - 201K (classic style) with knee controlled motor; 201K (classic style) with hand crank; 201K (aluminium body) with foot controlled motor.
