11 hours ago, BDAZ said:
I only use #24 snaps and use both Gold Star's and Tandy and all are perfect! I position a 4 ton jack next to the rear and set up the press so that the fully extended handle is resting on the jack at a low angle. Then I simple crank the jack to the level I want . The 2 ton arbor press is definitely overbuilt but I don't push it. I generally use it for smaller embossing plates when I want to maintain pressure for a while to get a good impression.
Bob
Sounds good.  Thank you for the replies.  I think I will pull the trigger on one of those.
You wont be sorry. Get a batch of snaps too.
