garypl Posted June 8, 2018 Report Posted June 8, 2018 43 minutes ago, AJ2018 said: Does anyone know why faded dye marks are left around my design ? , I knifed the design then I dyed it with alcohol based dye and when it dried out it showed the faded marks around the design, It looks like an offset marks from the design , did this happen to anyone before ? What causes it so I can fix the problem in later projects . Thanks Picture would be helpful... Quote Cowboy 4500, Consew 206RB-4
Members AJ2018 Posted June 9, 2018 Author Members Report Posted June 9, 2018 On 2018-06-08 at 3:29 AM, garypl said: Picture would be helpful... Hi Gary, here is a pic, the dye I am using is Fiebing alcohols based dye. Notice the ring marks left around the design. What is causing that ? Can it be fixed or should I cut a new piece. cheers, A.J Quote
Members AJ2018 Posted June 18, 2018 Author Members Report Posted June 18, 2018 some more pictures , still have to stitch the pad that is why i still have stitches on the holes. this cover has a different beautiful color finish as you see. but the color mix ratio is hard to get without having paint experience. what do you think guys, lets see what you got and lets learn from each others. cheers, A.J2018 Quote
