Thought I would share this piece with you Folks.
The dimensions are approx 12 inches tall by 8 inches wide. 10 OZ hide on front and a super thin, tan pig skin backing.
The Cross is tooled and raised and painted British Antique brown and the rest is Blue dye and all coats are buffed. A protective coating will be applied and buffed to a high sheen.
The "Jesus" wood carving is white oak, spray painted and glued on the cross.
The piece will end up as a hanging 'wind chime' when completed.
The main idea was contrasting colors and the use of wood in the Collage.
Sam:)
Well done, and cool color combination.  Any reasoning behind the overall shape?
YinTx
Thanks Folks!
The shape came about by having a piece of scrap that needed work. I plan to make this into a hanging wind chime so the shape is probably better than just a rectangle. I will show the final piece when I finish!
14 hours ago, jmkjmk2 said:
keep up the faith brother!  I'm a believer!
Amen my Friend:)
Oh, ok.  I thought maybe a coffin or something, and I was a bit confused...
YinTx
YinTx
I didn't even notice until after I made the piece but you're right , it does look like a coffin.
Sam:)
