Treesner Report post Posted July 20, 2018 hey guys I've been trying to put a 1/4 grommet in some thick webbing and am having issues with the grommet bending (brass) and then finally tearing out. I've checked my hardware store for the thinest washers I could find to reinforce/ make a wider area but I can only fit a washer on one side due to the length of the grommet. Also bought these Osborne grommets which are stainless steel, only stronger version I could find than brass but they'll still a bit short. Any source for more heavy duty grommets and or longer ones so I can fit 2 washers and make them HD myself Quote Share this post Link to post Share on other sites
csosborne Report post Posted July 20, 2018 2 hours ago, Treesner said: hey guys I've been trying to put a 1/4 grommet in some thick webbing and am having issues with the grommet bending (brass) and then finally tearing out. I've checked my hardware store for the thinest washers I could find to reinforce/ make a wider area but I can only fit a washer on one side due to the length of the grommet. Also bought these Osborne grommets which are stainless steel, only stronger version I could find than brass but they'll still a bit short. Any source for more heavy duty grommets and or longer ones so I can fit 2 washers and make them HD myself good afternoon, My name is Daniel with C.S. OSBORNE & CO. We have two types of grommets one being plain rimmed and the other spur rim. Spur is for thicker stronger material because it has teeth around the rim for a stronger hold also. any questions send me an email at: cso@csosborne.com reference# grommets101 thank you Daniel C.S. OSBORNE & CO Sales Quote Share this post Link to post Share on other sites
