I recently picked up some used x-ray film from a veternarian friend of mine and want to use it for templates. How should the film be cleaned before using? I would hate to leave any silver residue on the leather.
Thanks, Doug
Doug,
I would just wipe them with plain water. The silver is already fixed to the film, and ruboff or transfer has never been a problem for me.
Bruce Johnson, DVM
  • Ambassador
Use it for backing your work too. I use it instead of packing tape or cardboard when tooling. Plus I use it for stiffener when making album covers, book covers, picture frames etc.
pea-aire'
One word of caution when using un-exposed xray film. The stuff still on the film does come off when wetted. I would only use that film for stiffeners for album covers or whatever. Xray film work great for such use. Exposed or developed xrays can be used for carving/backing stamping without any problems. Carl
  • Ambassador
by the way, Doug. When I make binders/albums, projects that need or could use a bit of stiffener, I cut the xray film to size and glue to the project. I tool and finish it and simply use dividers to measure around the film the amount that I want for sewing or lacing. That way I have a backing, template and stiffener all in one and never remove it from start to finish.
Thanks for the suggestions and help. I've been using the template material you can purchase at Wal-Mart in the sewing and quilting section. It is hard to cut very acurately so I thought this x-ray film might do the trick.
Doug
I use photocopy transparent film (I think his name is vinyle, a plastic), is better than xray film or print in paper. Sometimes I print my patterns from my computer to the laser printer in the transparent films and after I trace the pattern on the leather easily.
If you have near from you a printing press or a printing works store they use a similar film to the xray one and within toxic waste. Also there is a transparent or translucent plastic for binding photocopies (is like craftaid plastic with one millimetre thick) which you can made your patterns for to cut the leather pieces.
