Members Resin Posted December 7, 2018 Members Report Posted December 7, 2018 So Im curious as to how yall tool weighted lines. Im working on a piece that is going to feature the ogham alphabet and after cutting the lines with the swivel knife Im at a loss for what to do. Do I just leave it like that? Quote
bermudahwin Posted December 7, 2018 Report Posted December 7, 2018 Ogham, is a single straight line alphabet, so if you cut it definition becomes harder. I am showing ogham and latin for H, usually they would have been on the corner of a post. (from Wikipedia) You could add definition by shaing one side, or both, but having tried that with Runes it looks odd to me. When I did runes I built them up a bit, cut the outline and shaded from the white area to the cut. It was about 30 years back, so I have no photos sorry. Quote No longer following it.
bermudahwin Posted December 7, 2018 Report Posted December 7, 2018 If it were authenticity you were looking for, single cut, sharply bevelled would give the shape of cuts in wood or stone. Quote No longer following it.
Contributing Member fredk Posted December 7, 2018 Contributing Member Report Posted December 7, 2018 I would use a groover to cut a, er. . . groove, rather than a cut line. I use woodcarver's V and U chisels for cutting certain grooves. I also sometimes, rarely, use the Tandy V gouge : https://www.tandyleather.eu/en/product/craftool-adjustable-v-gouge-2 Quote Al speling misteaks aer all mi own werk..
bermudahwin Posted December 7, 2018 Report Posted December 7, 2018 37 minutes ago, fredk said: I would use a groover to cut a, er. . . groove, rather than a cut line. I use woodcarver's V and U chisels for cutting certain grooves. I also sometimes, rarely, use the Tandy V gouge : https://www.tandyleather.eu/en/product/craftool-adjustable-v-gouge-2 That's a good shout, too, I'd have never thought of it, H Quote No longer following it.
Contributing Member fredk Posted December 7, 2018 Contributing Member Report Posted December 7, 2018 Even tho the OP has cut his lines he can use those to guide a groover. A stitching groover would do the job too Quote Al speling misteaks aer all mi own werk..
Members Resin Posted December 7, 2018 Author Members Report Posted December 7, 2018 Well I can always remake no problem. Only a bit of leather will be lost as I am doing a bookmark. I may use the piece to test both of yalls ideas and see which one I want to use more Quote
