BrendaMason Report post Posted December 30, 2018 Suggestions on what you use to glue liner fabric inside a leather bag. I used double sided tape and then stitched around the edges, before. Looking for something more durable, yet won't ruin the fabric. Quote Share this post Link to post Share on other sites
Dwight Report post Posted December 30, 2018 Contact cement has worked for me for years on end. May God bless, Dwight Quote Share this post Link to post Share on other sites
BrendaMason Report post Posted December 30, 2018 Dwight, the fabric is still pliable with the contact cement behind it? Quote Share this post Link to post Share on other sites
chrisash Report post Posted December 30, 2018 (edited) I used a carpet spray on tin to spray on, I taped over the borders prior to spraying etc so the glue only went where needed, then removed the tape and rolled on the fabric, there was no seep through and time enough to roll the fabris flat and remove any creases This was POly/Cotton to Horoween Edited December 30, 2018 by chrisash Quote Share this post Link to post Share on other sites
Dwight Report post Posted December 30, 2018 4 hours ago, BrendaMason said: Dwight, the fabric is still pliable with the contact cement behind it? Yes it is, . . . it is a bit stiffer, . . . but I use a very light coating on both, . . . mostly insides of gun bags, wallets, purses, . . . stuff that don't flex that much anyway. One thing you can do is only do the edges, like many handbags are done. They use some kind of rubber cement or double face tape to hold the liner to the zipper and to the leather, . . . sew all three together at the same time. I prefer contact cement. Very thin fabric, especially if it is light colored can let it show thru, . . . Mess with it, . . . you'll probably find you like it. Put a dab down on the fabric, . . . use an old credit card or putty knife to spread it out real thin, . . . dry it with a heat gun, . . . have a go at it. May God bless, Dwight Quote Share this post Link to post Share on other sites
