Ahh the slow cooker and it's many uses, I've used it to render out leaf lard for cooking, I suppose I could try a run at tallow. Pretty sure I saw cuts meant just for that at our local butcher. Thanks
No worries. I just asked the butcher for the "offcuts" from lamb/mutton that were headed for the scrap bin.
  • 3 weeks later...
Thanks for the advice, butcher pointed to the loose cuts section, it's not as cheap as I thought but 1.49 a lb won't kill me. Gonna clean it up a bit, cut it into chunks and have a go at the crock pot. Looked it up on a few pages, the consensus seems to be 1/4 of water so the crock doesn't shatter and chop the suet into clean chunks. Cook it for 6-8 hours then strain through cheese cloth. By the end of the 8 hours the 1/4 cup of water should evaporate out I assume but if not it's not that hard to separate fat from water.
  • 2 weeks later...
I don't think I put any water in, just threw the lot in the slow cooker, left it on low until I had crispy bits in the bottom and poured it out through a sieve. Can't get much simpler, I reckon.:)
  • 2 weeks later...
I have also been thinking about this subject!!! Smiths leather balm uses almond oil in there balm, I have been reading that almond oil will also go rancid. I wonder if they put a preservative (which would not be all natural like the advertisement claims) in it and if not did they consider that it would go rancid over time. I have also looked at castor oil, I don't know much about it yet but researching!! Mink oil, I recently bought a gallon of Think Mink pure mink oil for the mix, smells musky, not too pleasant which is leading me down the essential oil fragrance rabbit hole to cover up the smell.
