Members KAW Posted August 16, 2007 Author Members Report Posted August 16, 2007 (edited) Snakehorse saddler, I have seen the first tape Brian put out and it was mostly basic braids and knots and would be informative for you I think. The advanced one I haven't seen yet. I would start by getting your braids and simple buttons down first ( where you can do them in your sleep and as straight as an arrow) then you should learn the correct function and construction of each peice of gear you intend on making (if you don't know) if its going to be working gear( balance, lenths, ect). I'm saying this as there is alot more to making quality gear that will last than just braids and knots. You can't go wrong with any videos, books, and experences, you will learn from everything if you want to do the best you can. So I would suggest you start with the basics get them down real good then move on to bigger project whatever they may be just keep in mind that the function of the peice must be there FIRST. Edited August 16, 2007 by KAW Quote
