Juki DNU1541 top tension unit
I have a stripped top tension knob - plastic - and would like to either source a new  knob or even better - know the thread of the post and replace with a metal knurled knob or wing nut.
EVEN better is to get the part in the manual which is metal knurled Thread Tension Nut  B3125-012-000
Thanks in advance for any assistance.
Murray
Edited by plinkercases
wrong image
"Oh my God....I beseech thee grant me the grace to remain in Thy Presence; and to this end do Thou prosper me with Thy assistance, receive all my works, and possess all my affections" Brother Lawrence c.1614-1691
plinkercases.ca
Hello Murray,
I purchase most Juki parts from MJ Foley in New Baltimore, Michigan - USA.
They would be able to source either the steel tension nut or the plastic part.
Be aware that they typically have a $20 minimum order for parts, so you may want to consider if you need any other spares/replacements for your machine.
I see that you are in Canada.  I don't know their shipping policies, but it would be worth a call.
Regards,
Dale
Try Chris at Japan Sewing in Richmond Hill Ontario CA (905) 764-0100.
kgg
kgg
Kgg
That is where i got the machine. And coincidently i got to his shop today with the while assembly and he had a metal thumb screw that fit. Now i have that i may be able to match the thread and get a larger one which would be easier to adjust
Dale thanks for the lead and i will check them out as well.
plinkercases.ca
