Have you tried reverse stitching by rotating the project after about three stitches. Method would be to stitch three stitches and with the needle down all the way in your material allow the needle to come up about 1/4 of the way from it's deepest point then lift the presser foot off the material. With the presser foot lifted off the material turn your project around 90 degrees and sew back three stitches, rotate material again and continue to sew. Repeat at the end of seam.
kgg
Should have been 180 degrees.
kgg
kgg
You're right that is another option! Albeit a more time consuming one and harder if you're dealing with bigger projects. I'd like to learn both ideally.
Singer 111W153 walking foot & Siruba W122-356 coverstitch
To find an appropriste thread to seam tightness and strengths,  one hirers extremely competent engineering companys to test such articles.
On the other hand we do various test that measure up to our own specifications. What ever they may be.
I found searching many many articles and older post does help.
I found these industrials are similar in these functions so with test, the typical components mentioned, other brands are likely to produce the same results.
Hey Your always welcomed and encouraged to share any new results you tried, ( especially with photos ) even if they are separate topics. Im sure it can get narrowed down in short order.
So with that, any discussions on the thread route, tension and its mechanical help like take up spring function is prolly where your gonna end up.
:rockon:
Floyd
