Members Bmwmoa67707 Posted January 23, 2020 Members Report Posted January 23, 2020 On 1/18/2020 at 1:03 PM, garypl said: It mounts right where the servo motor mounts and the servo motor is moved to the bottom of the speed reducer. Might have to get a different belt, but it’s very easy to install. Where did you find it and about how much do they cost? Quote
garypl Posted January 23, 2020 Report Posted January 23, 2020 6 hours ago, Bmwmoa67707 said: Where did you find it and about how much do they cost? Call Bob Kovar at Toledo Sewing - 419-380-8540 - I believe they are @$200. Quote Cowboy 4500, Consew 206RB-4
Members Orchies Posted August 23, 2022 Members Report Posted August 23, 2022 Hi guys, just bought a Juki 1541 and wanted a speed reducer, then came across this topic. In UK and previously cut my old Singer 58K45 table to fit a two pulley arrangement underneath. Works well but had to make up my own belts. This time I might try this gentleman’s big pulley to avoid cutting new table. The pulley plus bush is quite cheap compared to box reducer with the US postage and import duties. I wonder if anyone knows the hand wheel shaft Dia on the Juki 1541 so that I can order pulley and bush in anticipation of the arrival of new Juki? For info, on my old Singer I run a belt from the big wheel on the Singer handle to a small pulley on the dual shaft. Then another belt from the same shaft, 8” pulley to the small pulley on the modern energy motor, a Jack. Quote
