calibre
How to maintain natural leather tones with basket stamping
Hi All,
I'm trying to achieve the effect shown in the attached basket stamp. The gel antiques that I have used tend to colour the raised areas of the baskets tamp that I want to remain a natural tone. I thought to apply a finish to the raised areas, but this seems tedious for the effect. Any suggestions on how to accomplish this effect?
Thanks!
Jason
So you want the color to stay in the "valleys" of the stamping and the "peaks" to be a natural tone?
I believe the way to do this is to learn how to carefully wipe with a flat item, one that will remain stiff and not conform to the patterns and dip down into the valleys.
Now, that's the theory -- hopefully somebody who has actually done this (which I vaguely remember reading about).
I bet this will require practicing on scrap pieces with this basket weave pattern.
Nearly there; two ways;
1. apply a resist first, eg a few coats of resolene, then apply an antique. Wipe off immediately - do not allow it to dry at all. Use kitchen paper towel folded up into a stiff wad block, or even a few layers on a block of wood - refresh the paper surface frequently; one wipe, new paper etc
2. use a dye like Fiebings standard type. Then use a cloth wad, wetted with alcohol such as meths or IPA, to wipe over the work. A stiff wad of cloth or wrapped around a bit of wood. Refresh the cloth surface frequently. The alcohol will remove almost all the dye from any raised surface but will leave some staining behind.
