2 hours ago, shoepatcher said:
dtklunk,
Early Pfaff 335's had only a 4 mm stitch length max.  I think yours is 6mm because of the N in the model plate.  Send us a pic of the reverse lever and the plate behind it.  H3 so 11mm lift of foot, B   means a B class which is for lighter material, S for  cloth.  No M which is safety clutch, no P for 4 motion drop feed.  She is dirty. I would go thru and clean it up, check for worn parts and even repaint it..  But that's me.
glenn
any suggestions on what to clean it up with?  Whats the max i can expect this machine to handle (thread/needle and veggie thickness).  The local sewing shop put a SV-71 servo motor under it since the earlier pic because the original motor was 3 phase. Will the speed reducer help the machine punch through easier?
Damn.  It is an early Pfaff 335 and  has only a 4 mm stitch length max.  That means the 6mm stitch length on the model plate number should read 6n for a 6mm max. stitch length.  I was wrong.  This old girl is going to need a massive clean on to get it back to good sewing status.   Be prepared to do that.
glenn
