LivnDream
looking for first machine
looking at 2 sewing machines    one is a juki lu563 without reverse for 500.00
other is a pfaff  145-h3-6/1c lmnp   for 450.00
i am looking to sew up to gun belt leather  what are your thoughts on these machines ?
joe
What total thickness will these gun belts be? Are you using veg-tan leather, bridle leather, or Latigo?
I used to own a Juki LU-563, with reverse. It was never able to match the holes in reverse, so I did Poor Man's Reverse to lock the stitches. That means rotate the work 180 degrees and sew over the last three or four stitches. The 563 uses a double capacity Juki LU bobbin. Mine was able to sew at least 1/4 inch of veg-tan and was also used to sew vinyl reflective safety vests with edge binding, all day long at times. It uses up to #138 thread, which is adequate for a 3/16 inch thick leather belt.
Anything thicker would call for #207 thread, which may be beyond the 563's ability to properly tension and clear the hook (maybe it can be tweaked to pass that diameter thread).
