Members Constabulary Posted May 15, 2019 Members Report Posted May 15, 2019 (edited) We haven´t seen the complete machine yet but you for sure need a new feed dog (see what I have linked above - thats dirt cheap) as yours looks quite worn and as mentioned before the hook tip is blunt / worn so replacing hook is the next thing. Machine is skipping stitches as it seems (hook is not catching the thread loop from the needle - that's what makes the stitches look long = skipped stitches) - either because of the needle hook timing, the worn hook tip or the hook is too far away from the needle I guess. The timing procedures are mentioned in the manuals I have sent you. The values for hook timing, needle bar hight and how the adjust the hook saddle are the same as on the Singer 111. Edited May 15, 2019 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
