Guest DoththeDoth
Looking for someone to lengthen some Synthetic Leather Straps
Guest DoththeDoth
I have some shin guards that I believe are made from Synthetic (they call it Syntek) Leather that Looking to get the straps lengthened on them
You should provide more information, such as your location.  Might be somebody on the same planet as you.  From your IP address, you appear to be in the Redmond, WA area.
Photos might help as well!
Tom
Guest DoththeDoth
Thanks, Tom.
That's correct, i'm in the PNW area, Redmond\Seattle. These are Shin guards used for Kick boxing\MMA sparring. They have a strap that is suppose to go around your upper calf, and another that goes around your lower calf through a D-Ring\Metal loop and then attaches via hook and loop Velcro. Unfortunalty I've got tree trunks for calves and need to get the straps replaced if possible with longer version.
Side view with metal loops and some of the straps
I recommend a local shoe repair shop.  They have the sewing machines that can handle sewing leather (and similar heavy materials).  That should be your easiest route to a fix.
You are posting as a guest. If you have an account, sign in now to post with your account.
