Thank You everyone for the replies and sharing knowledge!
When re-assembling the hookshaft and the lower shaft will the only thing to adjust timing on be the hook to needle? If there is more to it than that please let Me know.
Oh, yes I'm making a parts list that will be sent to Bob Kovar soon, it will include a servo motor and a variety of other must have parts.
Thank You,
Carl
 3 lower shafts - The hook, feed "stroke", and feed lift - All 3 need to be timed, IF they go them back in, with no binding.
Make match marks, take lots of photos and notes - You'll be more likely to get them close to start with, then - Good luck
Edited by trash treasure
The model number giveth, and the subclass taketh away ......... Sometimes
Trash treasure,
Thank You for sharing Your knowledge, I did take several pics and scribed both the feed rock shaft and the feed lifting rock shaft before removal. I needed to hear the procedure for the hook shaft prior to removal. This helps improve My confidence to proceed.
Thanks again,
Carl
