Hi,
Just got an old 111g156 machine. Its is not sewing properly. Does someone has a manual ?
Don't know the name of the part i am looking for.
First time user of this site/ community. You can see on the picture where it is rubbing , but can't load it
the Forum makes it a little tricky to upload the manual, if you Google - Singer 111g156 pdf -  the parts manual comes right up as the first hit.
Henderson is also a great place to find manuals.
https://www.hendersonsewing.com/manual.asp?page=42
One day I hope to learn how to sew.....
Singer 111W155 - Singer 29-4 - Singer 78-1 - Singer 7-31 - Singer 109w100 - Singer 46W-SV-16 - Adler 20-19 - Cowboy CB-4500
I don't think your picture got added, can you try and add again.
Here is a video of the 111g156 running, do you see the part in the video? or is it not part of the needle and foot area?
https://www.youtube.com/watch?v=R8zxFHHChlo
It is around the casing of the thread, under and inside.
I had to remove the foot to take it out, the casing who is screw to a shaft
The needle is rubbing on the outside part and make the stitches skip
My picture is more than 1.46mb
Is it the correct needle for the machine?  Is it a new needle, sometimes the needles get bent slightly and that's all it take to rub and skip stiches
this is a good video showing how the needle passes down and meets the hook at the right distance and time, to make a stich.  This machine he is using is similar to yours.
https://www.youtube.com/watch?v=Og1hM8iS22Q
It is where the bobbin is insert. The part under the hook ,who grab the thread. It look bend. It is tied up by 2 screws
I food the info looking at other sewing machine.
Somebody know where i can find pieces?
Living in Montreal, Canada
I put apart the machine. I had with the machine brand knew original needle.
It was working very well at the beginning.  Thread go stock very badly under. Then it stop sewing properly
The video is helpful to see how it should work.  Thanks.
Edited by Chris59
Raphael Sewing Machines, aka Techsew, is located in Montreal. They are a major dealer of industrial sewing machines, parts and repairs. Their address is: 155, rue de Port-Royal O, Montréal, QC H3L 2B3. Their local phone number is listed as: 514-270-1537.
As for the machine not sewing after a thread jam, it may be because the safety clutch popped when the hook got jammed with thread. Remove the top thread, then clear out all thread remnants from the hook and bobbin area, oil the hook well, them push down the button on the flat bed as you turn the handwheel away from you. The clutch should pop back into place and restore normal timing and operation.
Posted IMHO, by Wiz
