TZHunter Posted August 8, 2019 Report Posted August 8, 2019 Has anyone ever modified a manual turret punch to be used as a clicker for leather, rather than punching holes in steel? I can get a working turret punch cheap locally and was just wondering if anyone’s done this before? Pic attached Quote
Members klutes Posted August 8, 2019 Members Report Posted August 8, 2019 (edited) Interesting concept. Keep us posted if you follow through with it. Only issue I see is there enough clearance in the throat. Edited August 8, 2019 by klutes Quote Machines: Adler 69 , Adler 30-7, Adler 467, Cowboy bell skiver, Beilers embossing machine
TZHunter Posted August 8, 2019 Author Report Posted August 8, 2019 I’m thinking that all or most of the black round steel would need to be removed and replaced with two pieces of flat steel of desired bed size. Handle pulled would bring two pieces of flat steel together to “click” items. Others thoughts? Quote
Rockoboy Posted August 9, 2019 Report Posted August 9, 2019 I don't see any reason why it wouldn't work. It's the same principle, one works with steel penetration and the other is leather penetration (or cutting). Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
