Hi!
So for months I've been debating if I would make the step to buy some leather-craft tools. I always wanted to make some SD memory cases for my friends and family but never really knew if it was something for me. Anyway, I'm gonna try it!
I've made a list of tools that I think (Please correct me) are necessary/handy to complete this project.
I don't want to buy too much, as I don't know if this will be something I'm gonna keep doing, but I also don't want to buy some crappy tools. Just some decent tools that get the job done.
This is the SD case that I want to make:
https://www.instagram.com/p/B0QpK3vnXRK/
These are the tools I think I need for this project:
  1. Edger tool/beveller
  2. Rotary cutter (Can I use a Utility knife?)
  3. Burnishing Slicker
  4. Leather Sewing Thread
  5. Sewing Needle
  6. Leather (??)
  7. Stitching awl
My questions:
  1. Is this list complete or do I need to add/remove/change something?
  2. I want the same 'look' (aka thickness/color etc) as the example above. Can you recommend me some (decent) leather?
Thanks a ton!
  • Replies 25
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Hello Tyra, and welcome to the forum. Here are a few comments for you -
Have a look at YouTube videos on making wallets; the methods & principles will be the same as for your project. There are lots of videos, watch as many as you have the stamina for and you'll start to see how things are done.
You'll be using thinner leather, say 1,5 to 1,8mm thick, so you should get a smaller sized edge beveller, size 0 or size 1, and learn how to sharpen it. Again there are YT videos about this
As you will be cutting thin leather, and straight lines, a rotary cutter is fine, but you could use a utility knife if you already have one, and save a bit of money
You will need something to mark the line of stitching, and the spacing of the holes. I got a divider from a secondhand stall, about £2-50, say just over $3. Set it to 2 or 3mm; put one point on the edge of the leather, and mark the line with the other point
there are two options for making the holes - mark the position with a rotary stitch marking wheel then make the actual holes with an awl. Or use a stitching chisel which both makes the holes and sets the spacing. In theory a stitching chisel means you do not need an awl, but it's always useful to have one
Assembling the pieces for sewing is easier if you glue them in place first with contact glue
A block of beeswax is cheap and used to wax the thread, burnish the edges, and other odd jobs in leatherwork
A steel ruler or similar straight edge is used to cut the pieces
Search YT for videos on leather working tools for beginners, there are several, and as you will see, each one is slightly different
I assume you are American. Rocky mountain Leather supply has most of the things you need. At the moment they have an awl on offer at $16-99. As far as I can tell from the pictures it looks pretty good, and good value https://www.rmleathersupply.com
for sewing leather you almost always use a two needle method called the saddle stitch, find it on YT. RMLS have a mixed pack of John James needles (which are the best) and will cope with all you want to start with
Before you go straight into your wallets & cases you could try making something simple from cheaper leather, like key fobs. That will get you used to how the tools & materials work
Oh yes, I nearly forgot. You'll need a cutting mat; the usual self - healing cutting mat from a craft or hobby store. Get the biggest you can manage
Edited by zuludog
  • CFM
Hi, Tyra,
If I were attempting that project this is what I'd use:
  • Kyoshin Elle chisels: get the 3 mm version: a 2-prong, and a 6-prong should be the best options if you're not buying the whole set.
  • KS diamond awl: the small one matches the 3 mm chisels.
  • Economy poly mallet: should be an OK mallet.
  • KS Pro Edger: get either the #1 or #2. You might find edgers cheaper elsewhere but these come with a rod and two sheets of sharpening paper already.
  • Ritza "Tiger" thread: excellent German-made thread: very strong and comes already waxed—but not overwaxed like one I got from Tandy that waxed the heck out of my hands. Choose whichever colour best matches the leather you choose.
  • Needles: I use #4 because I mostly work with very fine thread (Tiger 0.6 mm), and because I like to save on thread (although once I took to piercing the thread BEFORE passing it through the needle's eye, the length of the needle no longer matters; thus, you could get #2 or #0).
  • A scratch awl (alas, the cheapest that Rocky Mountain Leather carries is about 8 times more expensive than the basic model Tandy sells, which is all you'd need—so much for my shopping list that was meant to save you money on shipping and handling).
  • Wing dividers to mark your stitch line (sadly, Rocky Mountain Leather is all out of the economy version, but these should be OK.
  • Leather to your taste. RML carries all kinds of types and colours, they sell it by the square foot, and they'll split it to your preferred weight for free—what's not to like? (NO, I don't work for them, LOL).
You could probably get away with a fork (free assuming you use a fork to eat with) for spacing and a nail (free if you have some laying around). You could get some needles (~3 bucks) from the leather section at Joanne Fabric or Hobby Lobby. Thread (5 bucks for 300 ft) can be had from Amazon for the cheap Chinese hand sewing thread. You could get some thread from the leather section at the hobby store but it is (5 bucks). The leather (~30 bucks) can be had from the hobby store too depending on which one you have; I've seen leather panels, remnants and a small piece offered depending on the store. It won't be great leather but it'll be relatively inexpensive.
All of this should run you about 50 bucks with shipping.
It sounds like you want to make a few of these at least so getting a shoulder of leather (about $50 + shipping) is likely more economical than Hobby Lobby leather. You get more and better leather but you pay a little more.
There are so many ways you could go with this really...
I wanted to dodge spending 100 bucks on a knife sheath and make my own and several thousand dollars later I have a decent little leather shop and an awesome hobby that I plan on using as a retirement gig when the time comes. The slope gets slippery. Need and want vary rather greatly in this pursuit.
Best of luck, hope this helps, and post pics. Be prepared to make some ugly stuff at first, we all do, its a rite of passage almost.
Hey thanks! I feel welcome here already!
Definitely gonna watch some more video's. Beside being very informative, they are also very relaxing to look at haha!
Thank you so much for all the information! I'm probably gonna buy my tools in the next couple of days, can't wait!
I'm from Belgium btw haha :)  But don't really mind buying from RML, as it looks like everyone loves their stuff. And I can't seem to find good stores in Belgium anyway.
Thanks again!!
15 hours ago, Hardrada said:
Hi, Tyra,
Thank you so much for all the links! Very handy as I'm new to all of this and there is so much to choose from!
About the Scratch Awl; can't I use the wing divider for this? Or am I seeing it wrong?
Thanks again!!
Thanks for the tips! I saw your comment and was just about to get rid of on old journal when I realized that the cover is from leather lol.
So I took a nail, fork and some stuff I had laying around and tried to make one, just to see if I liked it. Well, I'm hooked!! lol. Doesn't look like much but loved every minute of it!
Love your story, hope it works all out! Sounds like an awesome idea :)
Thanks again!
  • CFM
Thanks again!!
Aye, you could, but it might be awkward. Up to you. In a pinch, any pointy (but not very sharp) thing would do: say, a straightened paper clip or something from the kitchen. Some leathers mark easier than others. I've worked with the Badalassi Minerva veg tan from RML and I have to be extra careful as even my very short nails can mark it. English kip or chrome tan deerskin, I really have to press on the awl to mark it well enough.
Hehehe, the mention of the fork reminded me of this one video: Look, Ma: no tools! :P
Ahhh okay I see! Well guess I'll see how much my basket's value is after adding the most important tools, then I'll decide if I need a Scratch Awl haha :rolleyes:
And damn lol. That looks sick even with the tools that he used haha!
For a first thing, that look awesome, especially considering you went at it with the bare minimums. Used leather, a fork, a nail....doesn't get much more pure than that :) I'm glad that you liked it, now go get some good tools and start making things of beauty!
