Members Tlogan Posted December 17, 2019 Members Report Posted December 17, 2019 Looking at buying a like new cobra 18. Ready to sew. I mainly make belts, bags, wallets, note pad covers etc. Mainly belts tho. My thickest belt is 3/8". Will this machine work well for me? Thanks in advance for helping! Quote
Contributing Member JLSleather Posted December 17, 2019 Contributing Member Report Posted December 17, 2019 I'd get something a bit heavier. 3/8" is about 24 ounce leather. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
kgg Posted December 17, 2019 Report Posted December 17, 2019 II agree with JLS. Checking the specs on the Cobra class 18 it will sew up to 20 oz leather which is about 8mm (0.315 inches). This would be below your belt requirement of 3/8 inch (0.375 inches) or about 9.5mm. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Tlogan Posted December 18, 2019 Author Members Report Posted December 18, 2019 Ok just measure when I got home, it’s actually 5/16 oz veg tan. Still thinking to come something else? Just a hobbyist and found this machine for $1000 which is upper price point for the relatively low use but hand stitching belts is not an option for my patience Quote
Members sheathmaker Posted December 18, 2019 Members Report Posted December 18, 2019 I have used a Cobra 18 for several (many) years. It will sew 3/8" all day everyday. My main use with it now is 69thread through and 18 needle, but I have sewed many miles using 138 when making chaps and chinks. It is a great machine I endorse it completely. Quote Paul long-----108 Briarwood Ln. W-----Kerrville, TX--78028------830 367 5536-- pfl@cebridge.net
Members DrRick Posted December 18, 2019 Members Report Posted December 18, 2019 Hey, TLogan....for what you are wanting to do that machine should work fine for you. I invite you to check out Cobra Machines at the Leather Machine Company. If you have any questions about your machine you can call their tech support and they will be more than willing to help you. Here is the link for your specs: https://leathermachineco.com/product/cobra-class-18-compound-needle-feed-triple-feed-walking-foot-machine/. Rick Quote
Contributing Member JLSleather Posted December 18, 2019 Contributing Member Report Posted December 18, 2019 I'm not trying to talk you in to or out of anything. Get the machine you think you should get. I'm not the sewing machine guy by ANYBODY'S standard. But I know machinery a bit, and as a rule you want to run them FAR SHORT of "capacity".. an analogy that may be useful (or not - whatever): I bought this car. Speedo goes up to 130. Am I going to drive 120 ? - NO. Will I drive 100? Probably not. Did the auto maker, dealer, salesman, DOT..... anybody think that I bought this car to drive 100+, or that I should? Uh.. no. So WHY get a car that will (theoretically) do 130? So that when I drive 70 I'm running the machine at [ again, theory ] 50-60% of it's capacity. Running it at full on "what it's capable of" will burn it up quickly. Same goes for most equipment Flip the coin -- I don't see any sense in buying a porsche to go to the grocery store. Sure, it'll git ya there, but you spend far more than what was necessary. So somewhere between there, ask yourself what size thread you want to sew with (if that matters to you). Does the needle size matter? 135-17 needles WILL go through the leather, if that's your question. But I wonder if it has the juice to pull a stitch tight thru that Since you list location as "ohio", if it was me I'd call Bob and ask what he has and what he thinks. He might have something you can SEE RUNNING and decide if that works for you? Maybe ask Bob if that '18' isnt a Consew 206 with a paint job? I had a 206, and it ran great - but I would NOT use it to sew belts made of veg tanned leather. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members Tlogan Posted December 18, 2019 Author Members Report Posted December 18, 2019 Thank you all for your help! I did start by visiting Bob, he didn't have anything in stock at the time and said he rarely gets these machines in but 1-2 a year used. The new price appears to be very competitive, but for a hobbyist I'm just not able to tie over $2,000 into a cowboy machine, which is what led me to look on here at used machines and found one at a local holster company that they obtained new for doing wallets. I know there is a ton to learn like with every hobby so I'm trying to do as much research as possible prior to jumping in to avoid making the wrong decision. Because even at $1000 for this like new Cobra 18, that's a significant investment especially if its the wrong investment. Quote
Contributing Member JLSleather Posted December 18, 2019 Contributing Member Report Posted December 18, 2019 3 minutes ago, Tlogan said: used machines and found one at a local holster company that they obtained new for doing wallets That speaks volumes in itself. We wouldn't use it for holsters (generally 1/4" thick) but for wallets (most likely around 8 oz total). Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
kgg Posted December 18, 2019 Report Posted December 18, 2019 8 hours ago, DrRick said: Here is the link for your specs: https://leathermachineco.com/product/cobra-class-18-compound-needle-feed-triple-feed-walking-foot-machine/. A bit shy on info. I am going to ask what is the difference between the Cobra class 18 and a Juki 1541S which are about the same cost expect the speed reducer on the Cobra. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
