I bought a nice used Consew CP 206r and after several months have finally started to play around with it.
But I’m having an issue with the upper thread tensioner.  I unscrewed it because it looked cockeyed but got distracted and didn’t record the sequence the parts went in.  An online search for a detailed parts list hasn’t been at all fruitful.
Can anybody help me with a list or drawing or photo of the sequence?
What I have are:
a light spring w hook
a disc with flangers and hook
two saucer discs
a cupped disc
a black spring w split center
a outer threaded disc;
thanks for for your consideration
It's laid out in the correct order ,put the  take up spring in first & keep going with the rest of the parts.Make sure to put the spring in so it has some tension on it when you push on it,so when you first put in on it'll be approx. in the 6:00 position ,then push it up to the cut-out area it sets in.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
