Members Nightshade Posted December 21, 2019 Members Report Posted December 21, 2019 Juki DNU1541S not picking up bobbin thread. I've cleaned the bobbin case and bobbin area. No wayward threads to bind. I had a dust in there but cleaned with brake cleaner and reoiled. I've tried changing bobbins and needles but no go. I didnt try to see anything crazy thick eventhough I have a box reducer. I did notice that sometimes the shaft doesnt turn along with the hand wheel. But if I manually turn the shaft it works. Is this the safety clutch of horrible legend? Quote
kgg Posted December 21, 2019 Report Posted December 21, 2019 I would try resetting the safety clutch. The link should help with resetting the clutch. https://www.instructables.com/id/Re-engage-the-Safety-Clutch-on-Walking-Foot-Sewing/ It may also be the top pin that holds the hook basket in place got bent. If it is bent out of place it may have been caused by either not inserting the bobbin fully in place and hearing the click of the bobbin case lever the last time you put a fresh bobbin in, buildup of thread or not holding the thread for the first few stitches. The top pin is located at the top of the hook and you should be able to see it with the presser foot plated removed. kgg Quote
Members Nightshade Posted December 22, 2019 Author Members Report Posted December 22, 2019 Got the safety clutch reengaged. But still nothing. I'm not seeing the pin you're describing. Quote
Members Nightshade Posted December 22, 2019 Author Members Report Posted December 22, 2019 Or do you mean the post that goes through the bobbin? With the presser foot plate off it looks like the hook isn't catching the bobbin thread Quote
kgg Posted December 22, 2019 Report Posted December 22, 2019 If you do a search here for a topic called " Bobbin Issue - Juki 1541S " there are some really good photo' s of what you should see with the presser foot plate removed and may give you some additional info. kgg Quote
Members Nightshade Posted December 23, 2019 Author Members Report Posted December 23, 2019 My Google-Fu is weak but is this the thread... Quote
kgg Posted December 23, 2019 Report Posted December 23, 2019 Yes that is the one I was thinking of. Hope it helps. kgg Quote
