DaveCarey
Techsew SK5 feed roller problem
I use a Techsew SK5 bell skiver. The issue with its design is that the top feed roller is a tapered cylinder. This roller doesn't match the contour of the bell blade, therefore it takes a scalloped cut out of the leather rather than a flat skive. On bag panel edges, it's fine. But trying to take  flat skive out of wallet components is near impossible.  Is anyone aware of where I might be able to find a replacement roller that would match the contour of the blade?
Hi There, Have you got in touch with Techsew??
Here is a link that sells rollers for the top and bottom feed machines. http://www.fratellialberti.com/lang2/spare-parts-for-skiving-machines.html
