I have a Cobra class 4 sewing machine, was hoping it was going to do everything I was going to make.  Few years later I'm starting to need a machine for wallets and watch bands.  I use leathers between 2 to 5 oz either split or skived down.  Was thinking about a Juki 1508, huge cost but a solid machine, of course, the salesman is pushing the most expensive.  Looking for suggestions; good machine lower price.  I know, I know the subject has been most likely been covered a thousand times but I cruised the topics and didn't see a topic that seemed to fit.  Not sure what I'm going to end up with, but I need something...
While the Juki LU-1508 series are top of the line machines, they are overkill for wallets and similar thickness projects. You would get just as good a result with a Juki DNU-1541, or even the new Cowboy CB-1541 clone. These machines are medium duty, compound feed, walking foot machines that sew from a couple ounces up to about 20 - 24 ounces (depending on the density of the material. They use smaller thread sizes from 46 through 138, leaving off where your Cobra begins.
