Moderator Wizcrafts Posted January 29, 2020 Moderator Report Posted January 29, 2020 4 hours ago, Bmwmoa67707 said: 3 trips to O'Reilly's to get the correct length belt. I wasn't aware that O'Reilly's carried type 3L, 3/8" sewing machine belts. Or, did you buy an automotive 4L, 1/2" belt? This would be a mistake because that size won't fit inside the pulleys properly leading to premature slippage and wear of the belt and the bearings on the motor and reducer. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Bmwmoa67707 Posted January 29, 2020 Author Members Report Posted January 29, 2020 Wiz, it is a 3/8" belt, but it is an automotive belt.....it is not as "soft" as the other belt that came with the machine. It does fit down in the pulleys as it should, but it could be a bit stiff for this application. I will look for a proper belt as you recommend. Again thank you for looking out for me. Steve Quote
Members Bmwmoa67707 Posted January 29, 2020 Author Members Report Posted January 29, 2020 Wiz, another question....what is a type 3L belt? From you question about the 4L 1/2" I am tempted to think that belt width might be measured in 1/8" increments, therefore a 3L would be a 3/8" width and a 4L would be 4/8" (1/2")? Does the "L" mean that it is a "lug" belt? Also I would guess that a sewing machine belt might be somewhat softer and more flexible than the automotive belt? Another question while on belts.....how much tension so as not to over wear bearings etc.? Quote
Moderator Wizcrafts Posted January 29, 2020 Moderator Report Posted January 29, 2020 4 hours ago, Bmwmoa67707 said: Wiz, another question....what is a type 3L belt? From you question about the 4L 1/2" I am tempted to think that belt width might be measured in 1/8" increments, therefore a 3L would be a 3/8" width and a 4L would be 4/8" (1/2")? Does the "L" mean that it is a "lug" belt? Also I would guess that a sewing machine belt might be somewhat softer and more flexible than the automotive belt? Another question while on belts.....how much tension so as not to over wear bearings etc.? 2L, 3L, 4L, and 5L prefix – The “L” stands for light duty, and is designed for use with fractional horsepower motors. Meaning less than 1 HP. “L” style belts are often designated as light duty industrial, or lawn & garden. These are all called "V belts" because their taper resembles a V shape. You are correct that these belts vary in 1/8" increments in the USA. Type 3L = 3/8" across the top. The entire profile is different from automotive belts that are 1/2 inch across the top.Now that you know the best lengths, you can order proper belts from one of our dealers. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Bmwmoa67707 Posted January 30, 2020 Author Members Report Posted January 30, 2020 (edited) Wiz, understood, and thanks again! Edited January 30, 2020 by Bmwmoa67707 Quote
Members StitchLizard Posted April 15, 2024 Members Report Posted April 15, 2024 I'm here for the same question about the roller pressure. It's leaving wheel marks on my leather patches when applying on hats. I know there MUST be a way to adjust this, but I have no idea how. I've looked for days. I have a Consew 228r-11-1. A client brought me a hat that has absolutely no trace of roller or walking feet marks. Now they want more made without the indention. Quote
Members Constabulary Posted April 16, 2024 Members Report Posted April 16, 2024 (edited) Reduce the foot pressure and / or use a roller foot with smooth surface or rubber layer on the wheel Not sure if this one fits your machine https://www.ebay.com/itm/142979318355 Not sure how your machine is set up machine but this would be an adapter for the above roller https://www.ebay.com/itm/145397360986 If your machine is set up with the flip aside roller foot already then there is also an optional adapter for using plain industrial presser feet (f.I. with a Teflon sole) instead of the roller foot https://www.ebay.com/itm/143603134209 with installed foot: https://www.ebay.com/itm/165883555629 If you have a 1 row needle plate and feed dog then this set could be helpful when using plain industrial feet: https://www.ebay.com/itm/143603162021 Edited April 16, 2024 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
