Members zelix Posted March 9, 2020 Members Report Posted March 9, 2020 I'm new to leather work. I've got a year or so under my belt. I'm coming along okay but still have a lot of things to learn. I made a leather briefcase a while back. I used oil tanned leather. I didn't line it with anything. Anytime I use it the dye on it contaminates my paperwork. The briefcase works well for me and I'd like to be able to have a solution so I could use it. Hindsight I should have lined it with some pigskin or thin leather that wont bleed. It would be a nightmare to try and do that now. What would anyone suggest for this? another question. I've still have some of this leather. What glue should I use to line this with thin leather? Thanks in advance. Z Quote
Members Dwight Posted March 9, 2020 Members Report Posted March 9, 2020 When you say "contaminates" I assume that you mean the dye is rubbing off on your papers. My 1st thought would be to seal it, . . . the inside portion that is, . . . and the product I would recommend would be Resolene. NOW, . . . I do not work much with oil tanned leather, . . . so what I would suggest is you get some scraps from when you made the briefcase, . . . rub them against your papers to make sure they are doing the same thing, . . . and if they are, . . . coat the inside of them with a light coat of 50/50 Resolene and water. Use a small piece of a sponge, . . . and you will have to dampen it pretty good, . . . put a light coat of the Resolene/water mixture on it, . . . allow it to dry for about 4 hours, . . . then try to see if the dye will then come off on your paper. If I were a gambler, . . . I would bet this will cure your problem 100%, . . . by one or two light coats of Resolene on the inside of your briefcase. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members zelix Posted March 9, 2020 Author Members Report Posted March 9, 2020 On 3/9/2020 at 2:15 PM, Dwight said: When you say "contaminates" I assume that you mean the dye is rubbing off on your papers. My 1st thought would be to seal it, . . . the inside portion that is, . . . and the product I would recommend would be Resolene. NOW, . . . I do not work much with oil tanned leather, . . . so what I would suggest is you get some scraps from when you made the briefcase, . . . rub them against your papers to make sure they are doing the same thing, . . . and if they are, . . . coat the inside of them with a light coat of 50/50 Resolene and water. Use a small piece of a sponge, . . . and you will have to dampen it pretty good, . . . put a light coat of the Resolene/water mixture on it, . . . allow it to dry for about 4 hours, . . . then try to see if the dye will then come off on your paper. If I were a gambler, . . . I would bet this will cure your problem 100%, . . . by one or two light coats of Resolene on the inside of your briefcase. May God bless, Dwight Expand Hey thanks for the reply. I will give it a try. Quote
