Hi folks.
Recently fixed a few issues with the sewing machine having junky stitching. Yesterday I turned on the machine and BAM. Nothing.
I flip the switch on the box and the light in the switch comes on, but nothing ever displays. The machine won't run or operate.
I checked all the plugs in the back, as well as the wire to the wall to make sure it wasn't a problem. Kinda lost on where to go. We've had issues with this machine since we've gotten it.
It just has never sewed nicely even when we got it. Found a JUKI LS-341N manual and semi got it dialed in, the stitches are actually looking decent now... so I feel defeated that I turned on the machine and nothing...
If you bought this machine (and motor) from Techsew it may still be under warranty. If so, contact them about getting the motor replaced and for tech support with any stitching problems you have been experiencing.
In the meantime, unplug the motor and let it set a while. If there is a fuse,  check to see if has tripped or blown and replace it (you probably got a spare fuse with the paperwork). Then plug the motor back into the AC outlet and see if it has reset itself. If a new fuse pops, or fails to reset the motor, contact Techsew for a replacement. If your machine is out of warranty, there are other servo motors you can install.
Posted IMHO, by Wiz
