6 hours ago, blue duck said:
Love something different. You probably have already thought of this, but when you build your case don't forget to use large/deep enough feet to protect that hinge. Can't wait to see it.
Actually BD, I'm thinking of them for a pilot's case so the hinge will be at the top.
It's a good point though. If one of these hinges were on ,say, an attache case, the feet would need to be high enough to keep the hinge off the ground. That said, this particular hinge is 6mm thick (2mm leather wrapped around a 2mm CF rod).
  • CFM
could possibly be the reason you are not seeing a lot of leather hinges is the hinge is leather, it will stretch with time, the rod will become loose
it is a fantastic idea, for an item that will not be used every day.  their are reasons that we stopped using leather hinges and changed to metal
that would be durability. i DO LIKE IT ,
Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles
D.C.F.M
